Fast quick fix disable
janfsd
Phone: Nexus One
Post by janfsd »
Hi, I often type in other languages than english and always have to disable the quick fixes option. It would be great to have the option to toogle it on/off by swiping.
Keep the great work!
Re: Fast quick fix disable
Why would you do that ? Since version 1.23.0 quick fixes are now per language, so can you explain which problem you still have with quick fixes ?
janfsd
Phone: Nexus One
Post by janfsd »
Well the Polish language is not there. And I don't really need the Polish layout nor the dictionary. I like typing with the English keyboard. So whenever I write in Polish I've got to get into the options and disable quick fix. Soon after I have to enable it again for typing in English. That's why I would like to have a swype option for this. I don't know how doable is this since u say it is tied to the language itself. So maybe u could add English without dictionary.
Ah ok so you want to disable suggestions, not only quick fixes. I'll check how to do that...
Anyway polish is coming soon ;)
janfsd
Phone: Nexus One
Post by janfsd »
Yeah exactly suggestions, the thing is that in the options if you disable quick fixes suggestions is disabled too so I am used to disable quick fixes. Great to hear that polish is coming soon. Keep the good work ;)
No no it will not come soon, it's already here ;) (only the layout, not the dictionary, but you don't need it, do you ? ;) )
janfsd
Phone: Nexus One
Post by janfsd »
Great, now by switching languages is like disabling suggestions :) Thanks for adding this. I don't need the dictionary since I write most in english so it is ok for me.
