Great app with frequent updates...keep up the good work!
Not sure if this has been requested before but a great addition to this app would be an option similar to the Autotext on the Blackberries.
Basically you can setup shortcuts for words and phrases. On my Blackberry I would type "u" (without the quotes) hit the space bar then the autotext would change it to "you"
If i typed "cm" and hit space it would change it to "call me 212.555.5555"
You get the idea... a user shortcut dictionary.
Autotext
Re: Autotext
That's a pretty cool idea.
Re: Autotext
Yes, and I'd like to implement this just after the main bugs are fixed (if that day comes
Re: Autotext
I love it!!!
Its awesome...thanks so much!
Re: Autotext
Love the autotext feature. Something I really missed on my bb. Can this function be extended to work with the droids physical kb? If so, that would be awesome.
Re: Autotext
Just tried it now and the autotext didn't work. Used my phys kb to type out this reply.
Re: Autotext
Ok... I'll check when I have time but it's supposed to work, so if it doesn't it should not be difficult to fix (hopefully)
