QuickFixes settings
StormenDK
QuickFixes settings
Post by StormenDK »
Hey there
First of all .. great keyboard, really worth the money for the Pro :)
I have one small feature change request though. For the QuickFixes settings.
Currently this etting needs to be turned on to use the integrated QuickFix settings, as well as the user-defined ones and the Suggestions/Dictionary settings.
My problem is the QuickFix that the application does that I have no or little control over.
F.x. if I type 'i', which should not be capitalized in danish, it is automatically capitalized to 'I' every time.
Also when using applications that don't allow for the smileys button, when I enter a text and then try to make a smiley, the colon is always moved right next to the last letter.
Example: 'Have a great day :)' becomes 'Have a great day: )', unless I move the colon manually. It is rather annoying.
Problem is that if I turn off QuickFixes setting, then my dictionary and Suggestions don't work either.
So my suggestions are these:
1. Make a List in the settings with the QuickFixes that are intergrated in the keyboard, so I can either edit it, or disable it if needed.
2. Enable me to select whether I want it to QuickFix colons, semicolons, commas and punctuation characters, so they are automatically moved next to the last letter in the string.
Thanks in advance.
Grief
Phone: HTC Hero
Re: QuickFixes settings
Post by Grief »
I concur on all of the notes!
I would appreciate some kind of setting so that the automatically inserted space after each manually accepted word could be disabled, really annoying when you want to end a meaning with a dot for example...
I will see what can be done for the smileys, I know it's a problem (for "..." too)
For the quick fixes in other languages than english, it's actually the improvement I want to do in the next release: making the AutoText depend on the keyboard language. Today the AutoText depends on the phone language, so if your phone locale is English, you will get "i -> I" AutoText even if you type in danish
Will come soon ;)
Grief
Phone: HTC Hero
Post by Grief »
cyril wrote:I will see what can be done for the smileys, I know it's a problem (for "..." too)
Will come soon ;)
Great work!
The automatically inserted space after manually selecting a word from the suggested words is now an option you can disable.
Will I be charged again for downloading the new version of 'Smart Keyboard Pro' from SAM? I previously had 1.22.1.
I am not a SAM master ;) but no, you should not be charged for updates
Grief
Phone: HTC Hero
Post by Grief »
cyril wrote:I am not a SAM master ;) but no, you should not be charged for updates
You're most definitely some kind of master :P
