On Touchwiz keyboards, the haptic vibrations are very small, and it feels great + possibly saves battery having vibrations so subtle. On smartkeyboard pro, there is a much better vibrations adjustment compared to stock keyboard, but I wish that the bar could extend a little further allowing me to make vibrations even less than the minimum limit now. I want to mimic that subtle vibration like on the touchwiz
Thanks!
More Precise Vibration Adjustments
007alexlee
- Phone: Nexus S - 2.3.4
DJjay
- Phone: HTC Incredible S
Re: More Precise Vibration Adjustments
Even with minimal (but more than stock) vibrations on my HTC Incredible S, every few words I'll get the vibrator overrunning, which means I get some nonsense input from the keyboard. Have tried lowering vibration lower and lower but this still occurs. I guess it is a bug of sorts to do with lag from the input.
