Option to place mic key on th Alt page.
I like using the voice to text feature every now and then but I use the comma a lot more. It would be great if you added an option where it would move the mic key to the alt tab so that I could still have access to it yet make the comma quicker and easier to use.
Re: Option to place mic key on th Alt page.
you can disable the mic key and use a swipe gesture instead
