It's really good application.
How can I help for adding new language in application?
I want to add Armenian language.
Regards,
Vardan
New language
Re: New language
there are 2 steps:
1) describe the keyboard layout. For each key I need the letter and its unicode (UTF-16) code
2) create a dictionary. A list of words sorted by decreasing frequency is enough
there are 2 steps:
vgevorgyan
- Phone: HTC G1, Android 1.6
Re: New language
Can you send an example?
Re: New language
You can look at the xml of the stock keyboard:
http://android.git.kernel.org/?p=platfo ... ml;hb=HEAD
It would be something like this
