Hello.
Thank you. ú - equal long u and I dont know word with uu.
Czech layout
Re: Czech layout
Hi!
Almost fine.
ů with long press ), but l with long press )
Can you move "main" symbols on keys 1-2 px down? Because on firs row main and additional symbols without space.
Long press on L give to me "menu" with ) and strange symbol L with "." It must be ľ Ľ
Long press on P give 0
May be long press on l give ľ (Ľ) without menu and long press on ů give )
Almost fine.
Re: Czech layout
Hello.
I'm have dictionary without frequences.
Re: Czech layout
Better than nothing
But it will probably lead to poor suggestions, so better to have frequencies if possible
Re: Czech layout
Hello again.
Alphabetically ordered list http://rapidshare.com/files/370644274/seznam.zip.html
File in UTF8
File in UTF8
Re: Czech layout
thanks for the list, however I think that without frequencies it's difficult to use.
But I found another list, so "Czech for Smart Keyboard" is now available on the market, you can try it !
Re: Czech layout
Sorry. I could'nt try because my phone in service centre.
Re: Czech layout
Hello.
It seemed to me that the use AutoFix uncomfortable.
After 1st letter we have long pause.
Do you plan add support hardware keyboard translate in accordance with the layout?
Re: Czech layout
Not easy for me as the android emulator only supports qwerty, but yes it's plannedajiekc905 wrote:Do you plan add support hardware keyboard translate in accordance with the layout?
