Landscape mode language and other issues, Xperia Mini Pro
Re: Landscape mode language and other issues, Xperia Mini Pr
no, had other thing to do with more priority
don't worry it's still in the todo list ;)
christian_a_torres
Phone: Xperia Mini Pro 1.6
Post by christian_a_torres »
Issue 1 has been solved with me replacing the file /system/usr/keychars/mimmi_keypad.kcm.bin with the one from a Norwegian Xperia Mini Pro. This file is the one that maps the keys of the hard keyboard and is the file used by third party text input applications :D
Issue 2 is basically a non issue since, as previously mentioned, Smart Keyboard has a sort of different icon over the flashing cursor when using this blue function key. So its possible to distinguish where you are in the function realm. :D
Issue 3 is the one to fix. If this is possible Smart Keyboard would be the only 3rd party text input method to have this working for the Xperia Mini Pro's out there ;) Maybe it helps that in the file /system/usr/keyboard-config/layouts/qwerty-no-dk.xml (and all other layout files in that directory) Sym/áü button is id'ed as:
<key id="216"
meta="META_SYM"/>
Thanks for your continued help in this matter, hopefully it wont be to long before this can be fixed :D
christian_a_torres
Just wondering if there is any progress on the matter :)
christian_a_torres
Any news on the matter?
Son Goku ssj4
Phone: Xperia x10 mini pro u20i ~ 2.1 Eclair
Post by Son Goku ssj4 »
Hi. I've got a new xperia x10 mini pro phone for a month now and I've got the -same- problem.
Is there any progress? That would be awasome.
The Sym button just keeps doing the same thing as blue-square bottom-left.
I've got your Smart Keyboard Pro 3.16.0.
Physical Keyboard - disabled
Sorry, no news on this one at the moment.
christian_a_torres
Is it on the todo list? :D
