AndroidBlue and GingerbreadBlue for Extremely Blue CM6 theme
hotaru
Phone: htc hero cdma / cm 6 (android 2.2.1)
Post by hotaru »
i've been using cm 6 with jeagoss's extremely blue theme for a while, and while there are several skins for SKP that look ok on it, the colors are almost always a little "off"... so i decided to make some skins that fit in better with this particular theme.
first, AndroidBlue. pretty much all i did for this was grab the images for the android keyboard from https://github.com/jeagoss/jeagoss_extblue.
AndroidBlue.zip
(28.3 KiB) Downloaded 3694 times
second, GingerbreadBlue. this is basically the result of taking the GingerbreadBold skin i made and messing with the "Levels" adjustment in paint.net until the colors looked about right.
GingerbreadBlue.zip
(27.12 KiB) Downloaded 4687 times
anyone may use and modify any smart keyboard skins that i post on this site.
you may distribute those skins or modified versions of them for free.
you may not sell any of my skins or any derivative works of my skins.
oshi-k
Re: AndroidBlue and GingerbreadBlue for Extremely Blue CM6 t
Post by oshi-k »
I like GingerbreadBlue very much.
Maybe a GingerbreadPink??? :-)))
Thank you!
tryll1980
Phone: HTC Legend 2.2
Post by tryll1980 »
Download links don't work....
Sent from my Legend using Tapatalk
hotaru
Post by hotaru »
tryll1980 wrote:Download links don't work....
what links? the ones generated by the the forum to the attachments?
they work fine for me, and if they didn't, it's not like i could fix the forum software or anything...
Try outside Tapatalk, it doesn't behave well with .zip links
BigBootyJay26
Phone: Android Ally
Post by BigBootyJay26 »
I would love to see more colors and designs from these keyboards. thanx!
slinky317
Post by slinky317 »
I love the Gingerbread Blue skin! Can we make one with the thinner letters instead of the bolded ones?
(Posted from my HTC Droid Incredible)
Janknit
Phone: Verizon Incredible
Post by Janknit »
A huge yes to keyboard pinks!i
dopejayoh
Phone: White Samsung Galaxy SII
Post by dopejayoh »
I know this thread is quite old but I really like the AndroidBlue skin. One thing I would like changed, however, is the color of the suggestion bar. Any chance someone can make the suggestion bar black instead of white? Thank you.
