[Request] GO Keyboard Black and Default themes
ledoweb
Phone: Nexus One
Post by ledoweb »
I was wondering if someone could put some efforts in creating those two beautiful skins that I'm sure suit perfectly the style of Smart Keyboard:
#1: Black Theme
#2: Default 'White' Theme
Thanks a lot, in advance!!
CaRDiaK
Re: [Request] GO Keyboard Black and Default themes
Post by CaRDiaK »
+1 they look lovely.
Go (dark).zip
(7.1 KiB) Downloaded 2190 times
Go (light).zip
(9.65 KiB) Downloaded 1876 times
Graphical update :
Go (dark).zip
(13.69 KiB) Downloaded 1721 times
Go (light).zip
(29.13 KiB) Downloaded 1623 times
ledoweb
Phone: Nexus One
Post by ledoweb »
Really thank you man, they look almost identical to the originals.
One question, though:i think these are optimized for tablet, isn't it? Because on my nexus one all the pngs like enter/return, space, shift and del key look very very big, and are often bigger than the keys themselves. I hope you can fix this, thanks anyway!!
Sure I can,
you're half right ;) It has not been created especially for tablets, but the only android device I had at this moment was a tablet :)
As I got my nexus one back, I'll reduce the pictures to fit its size. probably in a few hours ;)
EDIT: here they are :
go dark reduced.zip
(14.1 KiB) Downloaded 1270 times
go light reduced.zip
(25.23 KiB) Downloaded 1148 times
vladeoff
Phone: O1 2.2.2
Post by vladeoff »
@meyergre
hi..I downloaded the files..What i get is all plain black.. :(
any idea? My phone is LG Optimus One. Thanks in advance...
That's strange, i just tested thème and didn't got any issue.which file did you download ?
vladeoff
Phone: O1 2.2.2
Post by vladeoff »
go dark reduce and the go light reduce files.. I re-download the files, still the same result..do you think uninstalling smart keyboard will solve the problem? because if i have to uninstall, i don't have any installer on my phone atm... :(
To be honest, I don't know. Try using any other skin on the forum before thinking re-installing the app, reboot your phone...
I'm currently using the go black reduced on my Nexus One without any trouble, so I really don't know what to suggest. :?
I guess you should be able to find a beta apk from this thread : http://www.dexilog.com/smartkeyboard/fo ... 6379#p6379
