thanks! i've removed the file.Link wrote:I have updated the original post attachment. Please remove this version so we don't get confused.
3DKey skin
Re: 3DKey skin
anyone may use and modify any smart keyboard skins that i post on this site.
you may distribute those skins or modified versions of them for free.
you may not sell any of my skins or any derivative works of my skins.
Re: 3DKey skin
I'm loving the 3DKey skin, its just what I've been looking for but any chance of getting it with Green key press highlight color instead of blue?
Re: 3DKey skin
I think 3DKey is the best skin and not only should be imported in the app, but should be default skin. I think we have to vote for a default skin for SKP.
Re: 3DKey skin
Thanks! I appreciate the support and feedback.PROXIMO wrote:I think 3DKey is the best skin and not only should be imported in the app, but should be default skin. I think we have to vote for a default skin for SKP.
Re: 3DKey skin
I like it so much, just can u make that more suits QVGA display with 65K color. Gradients don't look so good on that display, although i have seen it on bigger ones with more colors, and it is my fav.
Re: 3DKey skin
Sure, here is a 64K dithered version for mdpi. Try it out and let me know as I don't have a mdpi device to test with.PROXIMO wrote:I like it so much, just can u make that more suits QVGA display with 65K color. Gradients don't look so good on that display, although i have seen it on bigger ones with more colors, and it is my fav.
Edit: removed attachment
Re: 3DKey skin
It looks completely black. I cant see the buttons.
edit:
Forget about it this, it is not so bad (old 3dkey).. but buttons are too close together, can u make the same colour kbd but with this layout http://img51.imageshack.us/img51/2515/androidblue.png
Difference between yours and that 1 are that your key height is a little smaller and alt symbols are on the border of the button, and there is almost no space between buttons in a roll.
10x
edit2:
they are same height, i can see that now, it was just an illusion.
edit:
10x
edit2:
Re: 3DKey skin
Is there anyway you could make a white (or Droid X) themed verison of this skin? Thanks!
Re: 3DKey skin
Beautifull skin!
But in portrait-mode the buttons "delete" and "shift" are empty.
The same for the button for the microfone and the "return" key.
Same problem in landscape mode. Maybe the device is the reason for that.. it's the HTC Desire HD.
Re: 3DKey skin
Haven't seen any issues so far. Must be something with your phone or the version of the keyboard. You should email support.raylow wrote:Beautifull skin!
