Was wondering if you can please make a pink version? Thanks
Dark Galaxy with Android Green/ICS Blue/Purple/Gold/Red.
kittykatbaby16
Re: Dark Galaxy with Android Green/ICS Blue/Purple/Gold/Red.
Love your purple skin! Great work.
dan55
hi.
sent from galaxy ics skin...stunning. thanks
cheers
dan
cheers
dan
drakenabarion
- Phone: GT-i9000 cm9
Thanks for the themes. They look great.
Personally I am trying to make a set of coloured ICS keyboard skins, as I refer the lighter colours than the ones in the Galaxy theme. However, I am travelling for a few months so I dont have much access to a pc for the required image editing (mostly I use my phone).
So far, I made a skin using images from a CM9 holo theme engine apk (currently awaiting permissions from the maker before I share anything other than screenshots). However, I had issues with the pressed.9.png image from that apk so I tried using the one from your red keyboard skin, as I wanted to see if it would work. And it worked nicely, which is great. I have some screenshots here.
Would you mind if I used this image for my skin until I am home and able to make my own image?
If you prefer me not to, I wont use the image any longer.
Many thanks.
Many thanks.
- Jiia
- Phone: HTC Desire
I just had to come here to say thanks! The blue theme looks brilliant on my amoled screen. (Nerdgasm).
Sent from my Galaxy Nexus using Tapatalk 2
