glowkey (colors: blue, red, green, honeycomb!)
Re: glowkey [colors: blue, red, green!]
thank you for the skins! especially the honeycomb colors
Thanks a lot. You do a wonderful job
That's because I tried to add a glowing effect to the keys. I'm going to completely remove it from the *_white-text versions, and lessen it on the regular versions.7Stringer wrote:The actual lettering seems a bit fuzzy compared to other skins, almost as if it isn't hi-res. Overall, though, it looks and operates nicely. I like all the color choices. I'm running it on a DX, by the way.
Did you see that I updated the MIUI_black1.2_smallkey for you?
I'll do that, during testing I was thinking a grey one would look nice. I'll PM you when it's up.Microsoft wrote:WoOoW .. It's Very nice![]()
I hope make another one with a gray color .. Pleeeeeeeeease
Thanks for the effort, this helps me even more!mylenthes wrote:Ok, to save you some time I edited the file myself to suit honeycomb better. You can edit it and fix anything I may have broken and add it to your main posts if you like.
I'll definitly adjust everything, and post it soon as I can.
hi
blue blue still my fave.
was wondering if it is possible to add a coloured key press?
don't worry if not.
other than that it is perfect thanks
cheers
dan
don't worry if not.
cheers
dan
Yeah, I got the MIUI one and it is great!
Let us know when you've updated the other ones without the glow.
Do you mean the color of the key text? I know that the blue colored keys on glowkey_blue.zip turns white when pressed, is that what you mean?dan55 wrote:was wondering if it is possible to add a coloured key press?
beautiful! thanks a lot man! you did a great job
Re: glowkey (colors: blue, red, green!)
I'm uploading all the new versions of the current skins, this will take away the blurryness (shadowing) from the *_white-text versions, and adjust the black levels of the normal skins' shadow- this will keep the shadow, but it won't look like the text is blurred. Try it out!7Stringer wrote:Let us know when you've updated the other ones without the glow.
aaand... all the current skins are now uploaded with the changes you requested. Thank you!
