unfortunately it's at my office.
I was ummm 'working' and just happen to have photoshop open and then these png files just appeared...
just don't tell my boss.
I basically took the pressed.9.png and did a magic wand to select the color.
the filled it with paint bucket with the color I mentioned above, then lowered the fill and opacity on the layer.
I saved it and zipped it all up and.......
Droid X skin request
- meyergre
Re: Droid X skin request
Got it. Not sure it's the best way to change the color : try selecting the button area, then Picture > Settings > Hue/Saturation and play with the colors. the result should be identical to what you expected, and it should not "break" the 9-patch picture.
Like it ? buy me a beer
