Does it work if you open directly the draw9patch.jar program from the "lib" folder ?
if not, try re-installing Java from here : http://www.java.com/en/download/inc/win ... de_xpi.jsp, and then reboot your computer before trying again
skins make
- meyergre
Re: skins make
Like it ? buy me a beer
yakie996
- Phone: htc widfire 2.3.4
Re: skins make
noting..meyergre wrote:Does it work if you open directly the draw9patch.jar program from the "lib" folder ?
- meyergre
Re: skins make
That's CRAZY... well you can make a skin without this tool, just have a look at the google's documentation on 9 patch, and then apply the rules directly one your picture editor
Basically, you just have to add a 1 pixel transparent line all around your picture, and paint in black the areas which should expand. Look at any .9.png file one the themes around here, you should understand quickly
yakie996
Re: skins make
tanx for the quickly sevice xp but i give it up.. i let this work over on proffesionals
