Who can create a skin please
Re: Who can create a skin please
i do 2 pictures and now it don't wanna load ...
yakie996 wrote:i do 2 pictures and now it don't wanna load ...
What program are you using to edit the png's? I know, at least with photoshop, you don't even need draw9patch.
- meyergre
right, you can use draw9patch until you understand how it works, or to check if your pictures are OK, but it's not needed at all once you got it.
As TheTehk17 said, with only your picture editor, you can create 9 patch files - by the way, that's the way I proceed too
Like it ? buy me a beer
Yea... if anything, draw9patch is a pain to use. Just make sure all the pixels are black #000000.meyergre wrote:right, you can use draw9patch until you understand how it works, or to check if your pictures are OK, but it's not needed at all once you got it.
Meyer, have you ever considered theming? You know... making themes for rooted devices. There's hundreds of icons you can edit... you should have lots of fun with it.
- meyergre
Honestly, I've never thought about it.TheTehk17 wrote:Meyer, have you ever considered theming? You know... making themes for rooted devices. There's hundreds of icons you can edit... you should have lots of fun with it.
It represents a huge amount of work to draw hundreds of icons, so I'm not sure I would be concentrated enough to do it without decreasing the quality through time...
Skins for keyboard are funny, since it's only a dozen of picture to create in the same spirit, and it's done in about 30 to 60 minutes
For now, I have some development projects in my mind... But maybe later I would give a try at theming, who knows ?
It is a huge amount of work. I've been working on a theme for about an hour per day for the past 2.5 weeks and it's still not donemeyergre wrote:Honestly, I've never thought about it.
Check this out. I took the .apk with all the icons in it and put it into a zip. I think it's pretty cool... it's like a bigger version of a SM skin.
http://www.mediafire.com/?bm3mq3e6g5bdylf
*drawable-mdpi is where all the icons are*
- meyergre
impressive... did you actually draw every single icon in it ?
That file is only stock, it's not the theme I'm working on. I won't upload the theme file because I haven't released it yet, but I've edited most of the files, yesmeyergre wrote:impressive... did you actually draw every single icon in it ?
sorry my fould it was .pdn..TheTehk17 wrote:yakie996 wrote:i do 2 pictures and now it don't wanna load ...
Almost the same maybe, but .png is what you need to useyakie996 wrote:sorry my fould it was .pdn..but .pdn and .png is almoust the same??..
